Chrysler 313 motor oil pressure issue.
1 month 2 weeks ago #251532 by JOHN.K.
When I had the place at Oxley ,there was a really bad mechanic in one of the units there .........anyhoo,he rebuilt a WW2 jeep motor for a guy I knew ......... zero oil pressure when hot with new bearings......turned out the mechanic had used 20 under shells on a 30 under crank........but in the meantime ,to raise the oil pressure the mechanic had screwed the relief down tight .........when the right shells were fitted ,the oil pressure went sky high and the gauge burst .
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, PaulFH
1 month 2 weeks ago - 1 month 2 weeks ago #251534 by Mrsmackpaul
Just a quick reply the pump is driven vai camshaft has no reflection to throttle I disagree the faster the engine spins the faster the camshaft spins albeit at half engine speed
 I think the point might of got missed here
I think the problem only happens under acceleration and even with the motor spinning quick
once you take the foot off the go pedal, the oil pressure returns to normal
Last edit: 1 month 2 weeks ago by Gryphon.
1 month 2 weeks ago #251535 by cliffo
Just to be clear i will give a simple example....I am going down a SLIGHT downhill run at 1500 rpm with foot off pedal I have 50psi oil pressure and the slightest touch on the accelerator which HARDLY alters the rpm and oil pressure drops to 30psi
1 month 2 weeks ago - 1 month 2 weeks ago #251537 by jon_d
Possibly crankcase pressure.
Check the, change the, or fit a PCV valve.
Last edit: 1 month 2 weeks ago by jon_d.
1 month 2 weeks ago #251538 by cliffo
ran it with oil filler cap off .......no difference
1 month 2 weeks ago #251540 by jon_d
ok, another snippet of information.
You're asking for assistance but not very forth coming with all the details.
1 month 2 weeks ago #251541 by asw120
When this happens, would you think that it would be enough acceleration to make the oil slosh back and forth in the sump, or not really?
Just wondering if a baffle is missing in the sump, or the floating bit of the pickup that John mentioned has come of (if it has one).
The only time I had anything even vaguely like this was a 245 hemi Dodge, but I never did investigate, just put it off the road.
1 month 2 weeks ago #251543 by mammoth
Going back to basics and not trying to overthink. Change of throttle creates change of manifold vacuum, irrespective of engine speed. I would be looking for some sort of connection between manifold and oil system, eg manifold vacuum opens or closes a port/valve/flap related to oil gallery.
  • BillyP
1 month 2 weeks ago - 1 month 2 weeks ago #251544 by BillyP
Well, if thats the case , it certainly puts a new light on things................
Now i have absolutely no idea ..................
(accellorater linkage not bending oil line to gauge?????????)
Might have a vacuum assisted relief valve!!!!!!!!!!!!!!!!!!!!
...................Billy...............
I used to be a truck driver,
on a good day i can remember
  • BillyP
1 month 2 weeks ago #251546 by BillyP
Cop this ...............
Seems ass about face for the problem.............
But interesting enough....................
Vacuum pumps and oil pressure - Don Terrill’s Speed-Talk
.................Billy.....................
Time to create page: 0.591 seconds
