at4 brake parts
6 years 10 months ago #189978 by Old Fargo
at4 brake parts was created by Old Fargo
hello I am after a new rear brake cylinder for my 1965 at4 329. any info on a good Australian supplier appreciated (my one is not repairable) cheers
6 years 10 months ago #189981 by Blackduck59
Replied by Blackduck59 on topic at4 brake parts
Must be a mess if it cannot be sleeved
6 years 10 months ago #190015 by Dodgeydude
Replied by Dodgeydude on topic at4 brake parts
www.powerbrakes.com.au/
Reckon I got new ones cheaper than resleeves
The following user(s) said Thank You: Old Fargo
6 years 10 months ago #190021 by Old Fargo
Replied by Old Fargo on topic at4 brake parts
hello blackduck59 yes bleeder broken off and will have to be drilled out and helicoiled !!. so they say. cylinder pitted. cost of resleev+bleeder +freight is scary cheers
6 years 10 months ago #190022 by Dodgeanddetroit
Replied by Dodgeanddetroit on topic at4 brake parts
Try a brake supplier that has Protex brake parts. I got new wheel cylinders for a Dodge 700 D5n from ABS Brakes in Kewdale WA.
Quite a bit cheaper than resleeving.
www.protexparts.com.au/catalogue/
Regards
D&D
6 years 10 months ago #190029 by Blackduck59
If you know a few tricks the stuck bleeder is not a real problem but having someone do it does cost.
Hope the leads the others have posted work, a lot easier and less work.
6 years 10 months ago #190040 by Old Fargo
hello thanks for the information everyone, I will see how I go. thanks again. cheers
6 years 9 months ago #190093 by AB120
Replied by AB120 on topic at4 brake parts
i have used a dremmel tool with a round grind head to remove broken bleeders works well and if careful no thread damage
Graham
Time to create page: 0.515 seconds
