Inter D1110 Disc brakes upgrade..
10 years 6 months ago #140741 by hanknick
Hi , i have an inter D1110 van,with inter solid discs, i am looking to upgrade them to ventilated front discs, i have been told that the inter discs were the same as late 60s valiants, there are ventilated discs calipers and stub axles avail as a kit for these valiants, and was wondering if anyone had gone down this route for an inter.thanks again
10 years 6 months ago #140742 by asw120
Sorry to disappoint you, but the stud pattern is different (4 on 4-1/2", like Ford and 70's Valiants) and IIRC, the Inter has 12" discs. I also had one of those old Valiants (VC Regal 8 Safari), discs were maybe 9 or 10" from memory.
(someone with Valiants may correct me on that last bit)
10 years 6 months ago #140743 by Aussiehooker
any decent brake place can get you discs through D B A , and have them drilled to your stud pattern as for vented discs you may have to fit a different caliper to accommodate a wider disc cheers don
Time to create page: 0.412 seconds
