Bedford Brakes
7 years 7 months ago #181080 by HARDSHAR
Bedford Brakes was created by HARDSHAR
Would anybody have a diagram of the rear brake cylinders for a 1979 TK with spring park brake. Just had mine resleeved and I cannot remember the right order of reassembly. Took photos of everything but these. Thanks in advance. Sharpie.
7 years 7 months ago #181081 by Lang
7 years 7 months ago #181084 by HARDSHAR
Replied by HARDSHAR on topic Bedford Brakes
Thanks Lang, I went thru that site last night unfortunately it does not show the rear wheel cylinder. I need an exploded view . All my manuals are too early. Cheers sharpie.
7 years 7 months ago #181086 by Swishy
Replied by Swishy on topic Bedford Brakes
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationSharpee
Gudday m8
can U flash up a pic of wot U got
jist so we can be on the same page
Lockheed ................. Clayton-Dewandre .................. Girlock ???????
Here2helpTheNeedyNot the Greedy
7 years 7 months ago - 7 years 7 months ago #181088 by Lang
Replied by Lang on topic Bedford Brakes
Sharpie
This might be the answer: Photo Links don't work but info should be enough.
TK Bedford Brake Assembly
Here goes (I will assume that you have dissembled the brakes and are ready to reassemble them. If you need further information, just ask.
I presume that the wheel cylinders are still in situ - if you need instructions to install these just ask.) :-
1. Lightly smear the faces of the links, spacers and anchor plate with the approved grease (Duckhams Keenol). IIRC Keenol was a white waterproof grease, now discontinued, but see:-
2. Assemble the links and friction springs to the brake shoes as shown:-
noting that the heads of the bolts must be adjacent to the backplate when the brakes are installed on the vehicle.
Tighten the link bolt but leave the nut unpinned.
3. Check the tension of the friction springs as follows:-
a) Secure the brake shoe in a vice using soft jaw clamps and position the links at their maximum point of travel without over-riding the friction springs.
b) Install a bolt through the holes at the outer ends of the links, and, using a spring balance, check the load required to move the links:-
i24.photobucket.com/albums/c1...pscd4351fa.jpg
If the friction load is less than the specified limit (12 lb) renew the springs.
4. Slacken the link bolts sufficiently to assemble the links to the anchor plate.
Align the links and friction springs, and tighten the bolts.
Secure the nuts with split pins.
Note the following:-
1. Engage the leading shoe in the shoe support before tightening the anchor plate nuts.
Tighten the front anchor plate nuts and shoe support bolts to the specified torque (37 lb ft).
2. Install the push rod anchor springs and the shoe return springs as shown:-
Note that the illustration shows the left hand (rear) brake - the right-hand brakes will be mirror image with the thicker leading shoe lining towards the front of the vehicle!
i24.photobucket.com/albums/c1...ps9b778af1.jpg
ensuring that on the front brakes the spring with the greater number of coils is attached to the leading shoe.
Assemble the right-hand front brake shoe return springs behind the shoes. (I've checked that this is what the manual says! This might not apply to 4x2 vehicles.)
All shoe return springs must be assembled with the squared end attached to the brake shoe:-
i24.photobucket.com/albums/c1...ps6e06a63e.jpg
3. Back off the shoe adjustment and install the hub and drum.
1. Lubricate the outer hub bearing with the approved grease and insert the complete bearing, thin end of the race first, through the inner end of the hub, and tap the outer race squarely into the hub until it is clear of the retaining ring groove.
Assemble the retaining ring in the hub groove, ensuring that it is correctly seated.
Insert the drift and tap the bearing outer race into contact with the retaining ring.
Note that these instructions are for a 4x4 vehicle front hub. No specific instruction is given for the rear hubs.
2. Locate the outer race of the inner bearing in the hub, thick end first, and tap home squarely against the hub recess shoulder.
Pack the inner race and rollers with the approve grease, and assemble to the hub.
3. Lubricate the seal and refit with the lip towards the hub.
Press in until the face of the seal case if flush with the hub.
4. Clean the contact faces of the brake drum and hub and assemble the drum to the hub.
5. Smear the threads with Loctite Grade AVV and replace the drive sleeve studs in the hub.
As stated, the above instructions are from a 4x4 manual, and no specific instructions are given other than:-
The rear hubs are similar to the front and the same service procedure may be adopted.
Install the rear axle shafts applying a smear of jointing compound to the mating surfaces.
Lock the nuts with Loctite grade AVV. Rear axle shaft stud torque 25 lb ft.
4. Adjust the brakes.
To adjust the brakes, jack up each wheel in turn and proceed in the sequence given below.
When adjusting the rear brakes, skotch the front wheels and release the parking brake.
1. Charge the system to operating pressure.
2. Turn the shoe adjuster anti-clockwise until the drum is free to rotate.
3. Turn the front shoe adjuster clockwise (see fig N21) until the shoe is hard against the drum.
Centralize the shoe by applying heavy pressure to the brake pedal, then release the pedal.
4. Back off the adjuster until the shoe is just clear of the drum, ie so that the wheel rotates freely without the shoe rubbing.
5. Repeat operations 3 and 4 on the rear shoe adjuster.
Repeat for each wheel in turn.
Illustration of brake adjusters:- i24.photobucket.com/albums/c1...n/IMGP8511.jpg
6. Push in the indicator rod on the air actuator until it contacts the piston.
The indicator rod is about the diameter of a wire coat-hanger wire (from memory) and should stick-out along the axis of the air servo.
See item 23 on this illustration:-
i24.photobucket.com/albums/c1...n/IMGP8509.jpg
If your vehicle is very old, the design of the servo might be different to the above illustration.
Found some photos
Last edit: 7 years 7 months ago by Lang.
7 years 7 months ago #181103 by HARDSHAR
Thanks guys for your help. The thing I forget to mention is that the back brakes are wedge brakes. The wheel cylinders are on the outside of the backing plate. I have all the shoes and drums on. As well as hydraulics in the wheel cyl there are the rods that go to the spring brake chamber mounted on the diff. In the cyl is two cups ,a spacer and a tube with a flat circle end on it. This tube has the rod going to the spring brake going thru it. This is the bit I cant remember how it goes. Cheers Sharpie.
7 years 7 months ago #181106 by HARDSHAR
I forget to add it is a 1979 KC ,16'' wheels and a factory fitted 253 v8.
7 years 7 months ago #181115 by JOHN.K.
Replied by JOHN.K. on topic Bedford Brakes
Sounds like Girling wedge brakes.The tube with disc end is the part that applies the brakes via the cylindrical part with the flat on one side(locks with the captive screw/do you have the captive screw?)There is a thick disc that seals the open side of the cylinder,and one rubber cup seats on this,the tube has the other cup,and goes thru this disc.If you find all this confusing,then have a look at the Army Mk3 Acco info on the Remlr forum.They had the same brakes). Important.....If your brake has pushrods and rockers inside the shoes,be sure its right......because the brakes wont work if not right.Regards John
The following user(s) said Thank You: HARDSHAR
7 years 7 months ago - 7 years 7 months ago #181116 by jon_d
Replied by jon_d on topic Bedford Brakes
These are from the Truck and Coach manual.
The whole thing is dependent on the little locking screw to stop everything undoing. Make sure it's good and the piston 'extension' can slide though the locking screw.
Last edit: 7 years 7 months ago by IHScout.
7 years 7 months ago #181126 by HARDSHAR
Thanks Jon-d, That is the picture I was after. Makes sense now how it goes together. It was the only thing I didn't take a pic of when I stripped the truck down. Cheers Sharpie.
