- Thank you received: 81
1947 2-ton dodge truck built by T. and J. Richards and Sons.
- HalfaDodgeTruckMan
1 year 8 months ago - 1 year 7 months ago #243885
by HalfaDodgeTruckMan
I have done a lot of research already on the truck regarding what model it is, I'll give the specs for it; I need parts for it.
Year built: 1947.
Model is: DD4-60
Engine code: T118G (236ic?) 25' long flat head side valve.
Wh.base: 160
Capabil: 2 ton
serial No: 90059390
I also have some photos of the truck (I'll post them don't worry) and my uncle and I working on it in the brush in the middle of nowhere Australia.
Year built: 1947.
Model is: DD4-60
Wh.base: 160
Capabil: 2 ton
serial No: 90059390
Last edit: 1 year 7 months ago by HalfaDodgeTruckMan.
1 year 8 months ago - 1 year 8 months ago #243886
Replied by HalfaDodgeTruckMan on topic 1947 2-ton dodge truck built by T. and J. Richards and Sons.
photo set 1.
Last edit: 1 year 8 months ago by HalfaDodgeTruckMan.
1 year 8 months ago - 1 year 8 months ago #243887
photos set 2.
1 year 8 months ago #243888
photo set 3.
1 year 8 months ago #243889
photo set 4.
Also note: started working on it at that point, cleaning and planning out a new floor for the truck; beginning of lubrication of the body and other parts.
1 year 8 months ago #243890
photo set 5.
Note: beginning of taking a look at the state of the engine and internal parts.
1 year 8 months ago #243891
photos 6.
When working on disassembling the radiator and taking it out.
1 year 8 months ago #243892
photos 7.
Note: need new water-cooling parts and new water pump, should also mention that one of the bolts (for the water pump) needs to be taped out; it's stuck in the block.
1 year 8 months ago - 1 year 8 months ago #243893
photos 8.
Note: how bugged the water pump is, more lubricating took place that day and removing the old butterfly hood arm (as it had broken into two parts).
1 year 8 months ago - 1 year 8 months ago #243894
photos 9.
Note: successful removal of the radiator and cleaning the cab and engine out, some checky photos also.
