1947 2-ton dodge truck built by T. and J. Richards and Sons.
1 year 5 months ago #246091 by Lang
Vintage Power Wagons have much of what you want.
You can get the card for the firewall and just use the old one as a pattern. A huge upgrade is to put dynamat or similar on the firewall before placing the card/ Likewise even a rubber mat on the floor (I always insulate as well) helps with noise and heat. Stick insulation like pink bats in the roof before putting on the hood lining.
1 year 5 months ago #246095 by Mrsmackpaul
Pretty much as Lang has mentioned
Most of the parts your chasing should be pretty easy to get via Google if your local parts supplier cant help
1 year 5 months ago #246096 by PDU
Doors appear to be quite good as is, perhaps some oil on hinges and rust repair will make life so much easier? :unsure:
Changing doors can be full of extra problems which are not evident until you commit yourself to doing it. Personally I would do what I could with what you have, without removing them. ;)
1 year 5 months ago #246101 by cobbadog
I bought a roll of rubberised insulation stuff with alluminium one side. Self adhesive. Did tge whole underside of Lorry our Hino truck. Reduced engine noise a lot n gave cooler floor. If possible do your firewall on the insideso under bonnet looks original. You can cut it to shapes n butt join the sections. I glued layflat carpet to tge roof as original lining fell out.
1 year 6 days ago #249025 by HalfaDodgeTruckMan
Just checking in, I'll be giving a big update some time soon; when I'm not busy I'll post some new photos
The following user(s) said Thank You: IHScout, theabundantlife
11 months 1 week ago #249450 by HalfaDodgeTruckMan
Things that happened, got the radiator rebuilt.
11 months 1 week ago #249451 by HalfaDodgeTruckMan
New tarp because the old one got torn up and where using the torn one to cover the back part.
The following user(s) said Thank You: IHScout, cobbadog
11 months 1 week ago - 11 months 1 week ago #249452 by HalfaDodgeTruckMan
More cleaning, lubricating and rubbing the body in baking soda and washing with water to get rid of rust and scum. Good news, the hand brake works now too.
Last edit: 11 months 1 week ago by HalfaDodgeTruckMan.
11 months 1 week ago #249453 by HalfaDodgeTruckMan
Finally spray the body with "WD-40 spray".
The following user(s) said Thank You: cobbadog, Lang, PaulFH, wee-allis
11 months 1 week ago #249455 by Morris
Halfa,
You are making good progress.
keep it up!
The following user(s) said Thank You: HalfaDodgeTruckMan
Time to create page: 0.503 seconds
