42 mack fire truck
11 years 7 months ago #105006
by browny289
42 mack fire truck was created by browny289
hey all'
any one have any information about 42 mack fire truck, Pump details or drawings. Would like to get the pump up and running but would like some info on it first to see whats involved
11 years 7 months ago #105007
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: 42 mack fire truck
Can you put up a picture of it, so we know what we are dealing with. Or supply a chassis number??
11 years 7 months ago #105008
by browny289
Replied by browny289 on topic Re: 42 mack fire truck
11 years 7 months ago #105009
by Beaver
Send an email to the Museum of Fire This email address is being protected from spambots. You need JavaScript enabled to view it. , they may be able to assist.
Include chassis no and/or old fleet number which may be painted inside cab.
11 years 7 months ago #105010
by browny289
will do thanks. number is still there on drivers door 118 i think..
11 years 5 months ago #105011
by browny289
hey all been doing some work on the mack. Had an exhaust leak between inlet and exhaust manifold, i call it the hot box found it was missing a bolt. So started pulling it down to do what i thought an easy fix new gasket new bolt but nothing is ever easy when puling off hot box where it mounts to the inlet manifolds the bottom mounting face on both sides where fully cracked off. I believe i have no chance of finding any to replace if anyone knows of any let me know. I have repaired them the best i could for now. Once i found the cracked chunks of cast i then remembered the whistling noise while it was idling so makes sense the big miss off idle.
still have to clean up faces on the hot box.
They have had a few repairs in there time.
Always checking out the forum so i think i need to do a lil posting aswell.
11 years 3 months ago #105012
by browny289
11 years 3 months ago #105013
by browny289
hey guys, after some advice on using the pump. I have a manual for the truck, going through the part for the operation for the pump i understand how to use the pump engage levers etc. The only part its not clear about is what gear to have the truck gear box in to drive the prime pump / main pump if i have it in neutral it will free spin i was thinking it should be in a gear with 1.1 ratio or im way out? .
11 years 3 months ago #105014
by Beaver
It needs to be in top road gear, IE 5th.
Ask some of the old firies at the station if they still have a "green reader" instruction manual. Operating instructions therein.
11 years 3 months ago #105015
Replied by Swishy on topic Re: 42 mack fire truck
WAG
if tiz a mack duplex box
put main in 3rd or 4th n auxilary in Neutral n may B prime the pump wiff a bucket of water
But wadda eye kno
lol
But wadda eye kno
lol
Time to create page: 0.498 seconds
