Jake Brake History Lesson
11 years 3 days ago - 11 years 3 days ago #125072
Those th@ can .......... n like read n
todays history lesson
the Jacobs Engine Brake
Clikit ...................... ClikClikClik
Q:? may B asked Later
Jake Brake History Lesson was created by Swishy
Last edit: 11 years 3 days ago by Swishy.
11 years 3 days ago #125073
by paulc20
Replied by paulc20 on topic Re: Jake Brake History Lesson
Just a general question, as so many people mention it, if Jacobs advise against using the brake for upshifts as quoted
"If the engine
brake is on,
shifting without using the clutch or
double-clutching (to use the engine
brake to reduce engine rpm--also
known as
"If the engine
brake is on,
known as
11 years 3 days ago #125074
Replied by Swishy on topic Re: Jake Brake History Lesson
Paul sorry M8
can't answer th@.... too modern fir me ... them auto shift doodadds
but magine ifn u can use the jakes successfully ...Y not
Nearly 4 got thisn from Geelongs Tramcar
Please read thoroughly
- Thank you received: 52
11 years 3 days ago #125075
by grumpy
Replied by grumpy on topic Re: Jake Brake History Lesson
Then after a while they put an extra switch in the dash so you could select the amount of engine braking with the Jake.
Mobil had problems with the KW's fitted with 903 Cummins ... the tanker would start to drift out when empty under full engine braking, especially in the wet..
Frank from Friendly Transport had a major loss when coming home empty from Mildura, locked the drive under engine braking (KW COE with a 350 Cummins), finished up out in the middle of a paddock somewhere out near Calder, again a wet road.
Never had the problems though with the green colored oil leaking screamers .... probably too low in compression.
11 years 3 days ago #125076
by Chocs
Replied by Chocs on topic Re: Jake Brake History Lesson
I think the Jakes rely on oil pressure Grumpy..
In order to maintain oil pressure you need oil,
.... on the inside of the engine...
That's probly why you only get Jakes for about 30 yards in ya Jimmy!
chocs
chocs
11 years 2 days ago - 11 years 2 days ago #125077
by waynestr
Replied by waynestr on topic Re: Jake Brake History Lesson
Me thinks I detect a note of sarcasm there chocs. I could be wrong. I may have been once before , I just can't remember. But I like it.
Last edit: 11 years 2 days ago by waynestr.
11 years 2 days ago #125078
by Chocs
Well Waynesta....
I think that may have been the chocs being just a bit norty..
chocs
chocs
11 years 2 days ago #125079
Replied by bigcam on topic Re: Jake Brake History Lesson
I drove a Mate's 3070 years ago, the 903 had done a camshaft which had been replaced, but the crap off the camshaft must have gone thorough the mains, had bugger all oil pressure at idle, and the Jakes worked like they do on a GM, as soon as it came back to idle the Jakes came off. True case, but it's a Cummins, LOL.
chocs
11 years 1 day ago #125080
by binder
Replied by binder on topic Re: Jake Brake History Lesson
cam I doubt the shrapnel from the cam would damage the mains unless he forgot to fit the LF516 filter cos its got to go thru it to get to the mains!! I think the problem was no one wanted to do the mains on a in chassis cos it meant started and oilcooler removal to get the side bolts out plus ya came out lookin like al jolson at the finish so they would get 3-4 rebuilds with the old mains and eventually spin one I hated doin em but but allways did and i could sleep at night
11 years 1 day ago #125081
by Slasha
1974 White Road Boss
Replied by Slasha on topic Re: Jake Brake History Lesson
Gotta Love the Jakes
Back in the day when I was driving Coaches up and down at a Vic snow resort, several times a day in a denning coach with a 671GM it was great having to run down the mountain on the Jakes UNTIL :-[
One afternoon Snow every where, All chained up on the drive and the B#^^*y muffler blew out :-[
I think everyone for 80 miles new I was coming off the Mountain.
Wasn't funny at the time, as it was rattling the snow from the tree tops, I think I had someone in a ute following me catching the possums as the dropped out of the trees
Time to create page: 0.534 seconds
