- Thank you received: 5604
Yanky Iron Fix II
5 months 4 days ago #251847
Replied by Mrsmackpaul on topic Yanky Iron Fix II
5 months 3 days ago #251854
by Miwi
Replied by Miwi on topic Yanky Iron Fix II
The following user(s) said Thank You: cobbadog, Mrsmackpaul, overlander, PaulFH, husky, asw120, V8Ian, wee-allis, Brocky45, oliver1950
- Thank you received: 1369
3 months 5 days ago #252698
by Southbound
Replied by Southbound on topic Yanky Iron Fix II
The following user(s) said Thank You: Mrsmackpaul, overlander, PaulFH, asw120, wee-allis, oliver1950
3 months 3 days ago #252714
by grandad
Replied by grandad on topic Yanky Iron Fix II
The following user(s) said Thank You: Lang, Mrsmackpaul, overlander, PaulFH, asw120, wee-allis, Brocky45
3 months 3 days ago #252715
I wonder why it is this long ?
3 months 3 days ago #252716
by grandad
Think it's to make it easier to keep the line straight, there's a mirror on the bracket at the front to follow the white line on the ground
3 months 3 days ago #252718
by Brocky45
Replied by Brocky45 on topic Yanky Iron Fix II
It also looks like the paint discharge is in the center of the rear??? So this machine must of had to straddle the previous line??
3 months 3 days ago #252719
by grandad
Looks like the big sign over the cab would have been for the oncoming traffic?
3 months 3 days ago - 3 months 3 days ago #252720
Replied by Lang on topic Yanky Iron Fix II
Grandad listened in trig lessons at school.
The back axle is the pivot point. A 100mm deviation of the front wheels from the line with a 10 metre wheel base and a 2 metre distance to the spray nozzle out the back will make the line wander 20mm. If it had a more normal 5 metre wheelbase the line would be wandering 40mm.
The long distance from the driver to the front gives a much better "aiming point" and deviations are picked up very quickly. The same track deviation with the same eye and driver reaction will correct in half the time on a long wheelbase compared to short. One of the main reasons you never see a sniper rifle with a short barrel or it is much easier to keep an aircraft with a long nose straight on the runway compared with a short nose.
Last edit: 3 months 3 days ago by Lang.
2 months 2 weeks ago #252944
by grandad
Time to create page: 0.663 seconds
