- Thank you received: 10
Is AB series engine a "Silver Diamond"?
- spinnerboy
11 months 2 weeks ago #249174
by spinnerboy
Is AB series engine a "Silver Diamond"? was created by spinnerboy
What engine series in AB? Can I use a head from later or earlier engines? There is an AL190 complete engine available, this compatible?
Thanks, Lenny
Thanks, Lenny
11 months 2 weeks ago #249178
by PaulFH
Replied by PaulFH on topic Is AB series engine a "Silver Diamond"?
AB 160 and 180 in 1964 had AGD 282 motor.
Think denoted Australian Gold Diamond.
AA 180 new in 1963 same motor though painted blue. Earlier AA 180 had the 281 motor.
Heads were changed from the earlier series.
Inter guys on here will know about your model.
11 months 2 weeks ago #249181
Replied by asw120 on topic Is AB series engine a "Silver Diamond"?
AB was gold diamond. A 6-281 (later) head is the same casting number as a gold diamond head.
Gold diamond was tilt valve, silver was vertical valve.
- Thank you received: 671
11 months 2 weeks ago #249183
Replied by 180wannabe on topic Is AB series engine a "Silver Diamond"?
I think an L190 engine will be an RD-372 (Super Red Diamond). A fairly different engine from SD and AGD.
Brett.
Brett.
11 months 2 weeks ago #249193
Replied by bparo on topic Is AB series engine a "Silver Diamond"?
look at the engine number. If it starts with 2 or 3 letters that's the engine type and the 3 numbers after it is the engine size from factory.
other than the 281/2/3 which I think were all coded 282 but had different inlet/ outlet maniifolds but were the same internals the codes went as follows
First letter A - Australian Motor cast and built in Geelong. American built motors didn't have the A but shared the same
next 2 letters in the smaller motors:
SD - Silver Diamond
GD - Gold Diamond
BD - Blue Diamond
then the size is the next 3 digits , usually 220, 240 or 264
The bigger trucks had red and Black Diamond motors and I have seen RD used for Red Diamond. I don't know what they used for Black Diamond to differentiate it from the Blue. They were usually in R180, R190 etc trucks
SD - Silver Diamond
GD - Gold Diamond
BD - Blue Diamond
- spinnerboy
11 months 1 week ago #249203
by spinnerboy
Replied by spinnerboy on topic Is AB series engine a "Silver Diamond"?
Thanks for replies and info, will check in more detail now what's there.
11 months 1 week ago #249211
Replied by JOHN.K. on topic Is AB series engine a "Silver Diamond"?
People used to overbore the Silver motors to a 240 ,but it left the cylinders very thin,and sometimes they would blow out.........you can sometimes find the 282/3 motors with an ADEV engine number ...........after IHA discontinued the motors ,the army arranged to have parts made all over so they could assemble new motors .,which had the ADEV engine numbers.
11 months 1 week ago #249236
According to the 1955 IH Service manual I had the difference in a 220 to 240 from the factory was the stroke. The bore stayed the same so they used the same everything except for the crank and conrods. Why would people bore a 220 and need to get custom pistons etc made?People used to overbore the Silver motors to a 240 ,but it left the cylinders very thin,and sometimes they would blow out.........you can sometimes find the 282/3 motors with an ADEV engine number ...........after IHA discontinued the motors ,the army arranged to have parts made all over so they could assemble new motors .,which had the ADEV engine numbers.
The following user(s) said Thank You: wouldyou
Time to create page: 0.489 seconds
