Replacement bolts / nuts / screws
11 years 3 months ago #119948 by Wacker
Hi just wondering where you guys source replacement nuts bolts screws and other fixings?? Is there an online source in aus that is good? Also, is replacing old fixings with stainless a common practice? 68 CDJ bedford, so imperial throughout!
Thanks. Wacker
11 years 3 months ago #119949 by indianman
G'day Wacker have a look in the yellow pages should find a few nut and bolt joints in there they should have all you will need
Jon
11 years 3 months ago #119950 by
Probably the most important thing is to be aware of is that sometimes their are reasons why they used a certain bolt for a certain fixing.
For decoration bits probably doesn't matter what you use. But for anything structural or has a load you should replace it with what it had. So I wouldn't use a stainless bolt where a high tensile bolt was. I don't think Stainless is generally very strong but I guess like most things their are many different varieties. (not even sure of how available they would be. Doubt would be much range)
But always go to a proper bolt place. Don't just get them from a hardware shop as they aren't really designed for engineering in mind and are generally only for building uses.
Also consider that many bolts in a truck are generally fitted bolts. And might be hard to get new bolts of the right size for proper fitment.
11 years 3 months ago #119951 by old scrapman
Wacker
Most stainless bolts are equal to mild steel , look at head of bolt for lines eg,3/5/or more and replace with same.Peter
11 years 3 months ago #119952 by Desotodav
I use Classic Fasteners in SA and highly recommend them. I struggled to find correct nuts/bolts and screws for the rebuilding of my 52 Desoto truck but had no problems finding all that I needed from Classic... www.classicfasteners.com.au/ .
11 years 3 months ago - 11 years 3 months ago #119953 by mammoth
The beddie is likely to be unf and unc throughout which are easily obtainable. Blackwoods might have a branch in Perth (if not they do mail order), but in any event you need to shop at a place that can do reasonable pricing. For example, Bearfast in Tamworth NSW sells you a box at wholesale rate, then any thing after is also sold at wholesale. For important bits use high tensile grade 5 or 8 (better) bolts, nyloc nuts and hardened washers. Some stainless can be used in stress situations but you need to be certain that the grade of stainless (there are lots of stainless steel alloys and what is good for a saucepan won't keep your wheels on for long) is right for the application, so as has aleady been said - use stainless for trim etc but play safe on the rest.
The only thread form which is being phased out by engineers supppliers is whitworth (bsf went ages ago) and as a result can cost three times as much as unc which looks identical (but isn't)
Last edit: 11 years 3 months ago by mammoth.
11 years 3 months ago #119954 by indianman
G'day as said it should be unf/unc but it may also be whitworth not a great hassle as whitworth and unc are interchangeable EXCEPT for 1/2" as there is one thread per inch (tpi) different one is 12 the other 13 IIRC.
If in doubt take a sample in to the bolt place and get them to check
Jon
11 years 3 months ago #119955 by heelerau
Thanks. Wacker
Wacker,
Rudds Engineering on Farrell road Midvale have a huge range of bolts and nuts.
11 years 3 months ago #119956 by
HI Wacker
Try Coventry Fasteners on the corner of Welshpool Rd and Furnace Rd in Kewdale..........I worked for John Holland Rail in the West a few years ago and they maintained many Track Maintenance Machines...American,British and European and we never had a problem getting nuts/bolts or fasteners from them.
Darryl
11 years 3 months ago #119957 by Blackduck59
Depends on where in Perth you are, Cov's as already mentioned have a good selection and they have more than 1 fasteners store. Blackwoods yes but not sure on pricing
Yellow pages or Google should bring up more suppliers, I am in Rockingham and have a local fastener place that has pretty good stock and reasonable prices.
