- Thank you received: 609
K Model Bedford Radiator
9 years 6 months ago #156806
by Pierre
Pierre
K Model Bedford Radiator was created by Pierre
Hi, having started strip down & refurbishing parts as I go, I've pulled the radiator out, which was leaking mid-way up the core & taken it to a couple of radiator repairers here in Adelaide.
A Replacement core runs anywhere from $900 to $1650 & apparently not a standard size & has to specially made! >
I've emailed Aussie Desert Coolers today as well to see if they have an alloy unit at a competitive price?
The original was made by National Radiators & is stamped '53,which lines up with the truck build date.
Any other "K" owners had to replace theirs & found a satisfactory repairer at a reasonable price?
or
Does anyone know if there is a modern standard radiator that will fit, with some minor mods?
or
Does anyone have a reasonable S/Hand unit for sale.
Help appreciated
cheers Pierre
or
or
Help appreciated
cheers Pierre
Pierre
9 years 6 months ago #156807
Replied by jon_d on topic Re: K Model Bedford Radiator
Can you post a photo of it?
I've got a very good, all most perfect Bedford NJM/SB radiator in the garage.
(or PM me your email address.)
9 years 6 months ago #156808
by Pierre
Pierre
Replied by Pierre on topic Re: K Model Bedford Radiator
Jon, sounds promising, I've sent my email address to your HCVC message bank.
I'll take a photo & measurements tomorrow.
Thanks Pierre
Thanks Pierre
Pierre
9 years 6 months ago #156809
by Pierre
Pierre
Pierre
9 years 6 months ago #156810
by Pierre
Pierre
Jon,
The actual core dimensions are 630mm High x 485mm wide x 70mm thick.
As you can see I'll need to retain the bottom tank with access for the crank handle, & the top tank has a screwed filler with a high neck.
I'll check out the Isuzu FTR/FSR cores & see what I can find & as you suggest a good radiator repairer should be able to work the tanks onto the new core if it's about the same size.
thanks for your assistance
cheers
Pierre
cheers
Pierre
Pierre
9 years 6 months ago #156811
Replied by mammoth on topic Re: K Model Bedford Radiator
Pierre, Although of cruder construction the old rads were possibly better than what you can get today so I wouldn't rule out a repair. For old time skills these days you need to get out of the metro area and deal with a repairer who is used to farmers bringing in sad cases from all sorts of antiquated machinery.
9 years 6 months ago #156812
I agree, from the pictures, it looks pretty good.
I'd be taking it to a specialist radiator place and get them to lift the tanks, clean it, make a new connection and do a little panel beating.
You might get away for a couple of hundred.
An FSR core is 570x640 or so.
JD
JD
9 years 6 months ago #156813
by Pierre
Pierre
Mammoth, Jon, your points noted.
thanks guys .
thanks guys .
Pierre
9 years 6 months ago #156814
Replied by on topic Re: K Model Bedford Radiator
Pierre I have had top & bottom tanks cleaned and core on my 34 bedford but you still having dramas I have a good Bedford radiator sitting in in my shed.
Any radiator bloke worth his salt wont have a drama with yours they are out there. Dave
9 years 6 months ago #156815
by Pierre
Pierre
Thanks Dave.
I've sweated off the outer support shroud & will cut out the rusted section & replace.
Should be able to find a reasonable core that will take my top & bottom tanks.Then find this elusive "out of town radiator repairman".
Failing that, Is the one in your garage for sale?
cheers Pierre
cheers Pierre
Pierre
Time to create page: 0.462 seconds
