Hydrovac Brake Booster
- HeyCharger
10 years 1 month ago - 10 years 1 month ago #142594
by HeyCharger
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Hydrovac Brake Booster was created by HeyCharger
Hi Guys. Anyone heard of these (or better still have one they want to loan me - permanently) for my 1942 Ford semi trailer bus restoration. I've never heard of them, but they are in the book. Thanks. Rod.
Proud owner of;
Last edit: 10 years 1 month ago by HeyCharger.
10 years 1 month ago #142595
by jeffo
Replied by jeffo on topic Re: Hydrovac Brake Booster
Had one on my Mini back in the day, popular with those old cars with feeble unboosted drum brakes.
Once the vacuum brake booster/master cylinder combo we see everywhere became standard fitment, Hydrovacs were forgotten.
I think there's now only 2-sizes available.
Bit of a pain to bleed so siting the unit properly is paramount.
10 years 1 month ago #142596
Replied by bigcam on topic Re: Hydrovac Brake Booster
Other thing I hate about them is that when the seal fails, the vacuum sucks the brake fluid out and you have no brakes, and because the brake fluid ends up in the vacuum chamber there is no tell tale oil leaks.
10 years 1 month ago - 10 years 1 month ago #142597
Yep! Been there; done that! Dodge 200 ex- PMG. Took a whole bottle of brake fluid over a month or so before I worked it out. (PBR VH-40)
ASW.
Replied by asw120 on topic Re: Hydrovac Brake Booster
ASW.
Last edit: 10 years 1 month ago by asw120.
- HeyCharger
10 years 1 month ago #142598
by HeyCharger
Proud owner of;
Replied by HeyCharger on topic Re: Hydrovac Brake Booster
ok guys. AS I know jack sh*t about this subject, would a Remote Vacuum Booster be suitable?
Proud owner of;
10 years 1 month ago #142599
by dieseldog
Replied by dieseldog on topic Re: Hydrovac Brake Booster
I found this and it looks simple enough.
dave78chieftain.zxq.net/HydroVac_brakes.html
If you follow the link to the Stovebolt page, there's a bit more there too.
10 years 1 month ago #142600
Replied by Lang on topic Re: Hydrovac Brake Booster
Charger
If you can put on a remote vacuum booster it is the go. I have put them on my Dodge Weapon Carriers and a Blitz. On those vehicles it takes under an hour by any home handyman.
The difference is a choice of applying in writing 24 hours in advance for permission to stop or having brakes as good as a modern Landcruiser - it is that dramatic a change.
If the Ford can be set up with a standard master cylinder without the hydrovac system you can put in a remote.
- HeyCharger
10 years 1 month ago #142601
by HeyCharger
Thanks Lang. I've heard that. And with my semi-trailer brakes, (which are solely hand lever operated) I've heard it's 30days... :-[
Thanks DD. Great info.
Rod.
Proud owner of;
Rod.
Proud owner of;
Time to create page: 0.430 seconds
