- Thank you received: 986
Karrier rebuild
7 years 2 weeks ago - 7 years 2 weeks ago #187424
Well, finally got around to at least starting the cab repairs/rebuild.
Sometimes don't fully realise just what I have taken on!
As can be seen, quite a bit of cancer in the lower sections of the cab, but surprisingly it is pretty straight without many dings in it. Will test the mig welder out, as well as my own expertise (HA!).
Biggest problem looks like being getting replacement box sections folded up for the cabin floor supports. The floor plates are flat and can use the old ones as templates.
mate came around and had a look and reckons that he had seen far worse than this refurbished, even the door lower sections could probably be simply removed with the angle grinder/cutter and new sections welded in. Just as well I'm retired and have little else to spend my time on!
Cheers, Dave_64
Karrier rebuild was created by Dave_64
Cheers, Dave_64
Last edit: 7 years 2 weeks ago by Dave_64. Reason: Text
- Thank you received: 5604
7 years 2 weeks ago #187433
Replied by Mrsmackpaul on topic Karrier rebuild
there aint no turning back now LOL
I was on the blower to Chocs a while ago and he mentioned some tool that you can buy that puts a double set in the panel you are putting the patch on so the new but welds up flash to the old bit but also gives it support
And on the other half of the tool it punches the holes for your plug welds
Apparently a real time saver and helps to do a much neater and stronger job |
If he sees this he might give you the low down to what this is called
The following user(s) said Thank You: Dodgeydude
7 years 2 weeks ago #187436
Replied by Dave_64 on topic Karrier rebuild
Thanks, Paul. Certainly like to know more about that tool, anything that makes it easier worth looking at, Dave
- Thank you received: 557
7 years 2 weeks ago #187437
Replied by Blackduck59 on topic Karrier rebuild
Flange and punch, air operated
The stepped section works a treat when welding, very little distortion and very strong.
Google will work to find it, think I paid around $90 for mine.
Can dig up the info on mine if you cannot find it online.
7 years 2 weeks ago - 7 years 2 weeks ago #187438
by dno
Limited Access Excavations.
Replied by dno on topic Karrier rebuild
Look forward to following the build Dave, some of these butt
welding clamps may be a good investment.
www.machineryhouse.com.au/W113#
Last edit: 7 years 2 weeks ago by dno.
7 years 2 weeks ago - 7 years 2 weeks ago #187441
Some good gear getting around these days, come a fair way from the old trying to hold everything together with vice grips or using 'G' clamps and pieces of timber/metal.
Mrsmack, Chocs sent me the link, thanks.
7 years 2 weeks ago #187480
by Fill
Replied by Fill on topic Karrier rebuild
Hi Dave
100_2505
fill quinn
, on Flickr
I bought this trolley on Ebay, I think for about one hundred and fifty dollars I think it started out as a lathe stand.
I have put the pictures up on my site before. ( sorry to the other viewers )
100_2813
fill quinn
, on Flickr
You would need a big lounge room to put yours in lol.We all like photos keep them coming
Cheers Fill
Cheers Fill
7 years 3 days ago #187992
Replied by Swishy on topic Karrier rebuild
Q:?
Iz Cogz further advanced than he sez he iz?
https://scontent-syd2-1.xx.fbcdn.net/v/t1.0-9/22406397_710515149148050_5723824954719824843_n.jpg?oh=8ab65fbf8e90415ca0d557eb4a1ad199&oe=5A753E52
https://scontent-syd2-1.xx.fbcdn.net/v/t1.0-9/22405764_710515512481347_6563345881667296370_n.jpg?oh=9906c8dbb9589cba22d1785b192921df&oe=5A7DB545
Noice shoppin jeep or pub run truck
ยง
ยง
7 years 3 days ago #187994
Chassis away at the sandblasters at the moment. Then start installing engine/trans. Tidy looking jigger, that. Dave
7 years 2 days ago #188004
Replied by JOHN.K. on topic Karrier rebuild
The cab on my Leyland Harrier tilt tray is far worse than that one.And was worse when the truck was still on the road.In fact some of the worst rusty cabs Ive seen were on fairly modern trucks(at the time).The windscreen and quarter window surrounds/frames look to be stainless or brass.
Time to create page: 0.667 seconds
