- Thank you received: 7
Lead Replacement additives?
11 years 4 months ago #117870
by gilly
Replied by gilly on topic Re: Lead Replacement additives?
Me too Acar. I have one on my 100 series turbo diesel cruiser that used to soot up the back of the vehicle, particularly when towing the caravan. Fitted the Fuelstar, it now averages 10.5 litres 100ks as a general run-around truck, no soot at all, & pulls like a train.
Yeah I know, comments like old wives tail etc, etc etc,
put the vehicle on the 5 gas exhaust gas analyser, 99.9% combustion efficiency, Nox right down also when under full load(no add blue either )
Run one a LPG dedicated BF ford, never had to pull the head off for valve work over 800,000 ks, gas bench test every 10,000 ks proved that wasted HC from the combustion chambers was still within specs at high mileage.
When plugs removed for change, the ends of the plugs always had a nice grey coating, as with other engines that had a fuelstar fitted.
A once of investment for any vehicle, that can be re-fitted to another.
Gilly
Gilly
11 years 4 months ago #117871
by John Whale
Replied by John Whale on topic Re: Lead Replacement additives?
hello all can they be bought as a one off ??? whale
11 years 4 months ago #117872
by gilly
Hi John,
If you purchase one, it will be to suit your size engine, no harm in going one up in size canister in case you wish to fit it to another larger vehicle down the track.
Gilly
Gilly
11 years 4 months ago #117873
by John Whale
thanks gilly might be worth a try cheers whale
Time to create page: 0.458 seconds
