- Thank you received: 47
Detroit Air Box Drains
11 years 7 months ago #107967
by paulc20
Detroit Air Box Drains was created by paulc20
I am planning to register my 73 Crusader in the next week or so, It has not been registered for about 10 years.
The air box drains from the 8V71 drip straight on the ground. Is this still acceptable to the NSW RMS. My 76 model has the drains piped back to the sump and I know some people have made catch tanks as well.
11 years 7 months ago #107968
Replied by Swishy on topic Re: Detroit Air Box Drains
do U want this as a permanent fix or just to get it thru Rego
temporay
U can plumb the 2 air box drains into sump n May B fit a one way valve so it dont suk up any oil
or plug the lines but after rego let m breathe
permanent fix
U can buy a setup to collect oil n then drain off once in awhile
GM Diesel Bazil also made a tank collectin system for his V6-53 in the Inter
ButWaddaEyeKno
temporay
permanent fix
ButWaddaEyeKno
11 years 7 months ago - 11 years 7 months ago #107969
by overnite
With the EPA the way it is in 2013,I've got a feeling you knew the answer before you asked the question.
Replied by overnite on topic Re: Detroit Air Box Drains
Last edit: 11 years 7 months ago by overnite.
11 years 7 months ago #107970
by paulc20
Replied by paulc20 on topic Re: Detroit Air Box Drains
- MasseyHarris55
- Ahhhhh thats what that does
- Thank you received: 32
11 years 7 months ago #107971
by MasseyHarris55
Fixing things one big shifter at a time
Replied by MasseyHarris55 on topic Re: Detroit Air Box Drains
Our Detroit engined busses 92 series had the breathers plumbed in to the tag axles witch had mush room breathers and a drain tap on them I thought it was quite clever myself prior to that it was half a 4ltr milk carton
11 years 7 months ago #107972
We run SFA
The only only patch under our trucks iz oil from the air tanks az we leave m open O/Night
Did hear the Air Box Drain Kits
ran back to the sump
and were known as a conversion for buses
as they did not like the oil on the ground @ the big bus stations
Screemers dun like idling around
When U use u're hook jiggr the screemer aint work n 2 hard
probly when U take off U will C a lot of white smoke from slurry n up but will clear when U labor it n drive az tho U stole it
We run SFA
- Thank you received: 52
11 years 7 months ago #107973
by grumpy
Replied by grumpy on topic Re: Detroit Air Box Drains
I woz gunna write that "REAL ENGINES DON"T NEED AIRBOX DRAINS" but that wouldn't go down too well with the Screemer Fans.
11 years 7 months ago #107974
by Chocs
Replied by Chocs on topic Re: Detroit Air Box Drains
Good thing you didn't write that Grumpy..
chocs
chocs
11 years 7 months ago #107975
by knighty
Lotsa Big Toys
Replied by knighty on topic Re: Detroit Air Box Drains
Ya sposed ta be nice on this forum grumpy, least chocs has a few manners .. i think, heres the collector on our KW, simple as long ya remember to empty it before the RTA waves ya in...jk..
Lotsa Big Toys
11 years 7 months ago - 11 years 7 months ago #107976
by Chocs
Copy Grumpy..
I think they have all gone to sleep now......
Whats an air box drain?
I know we have table drains, spoon drains..down the drains...
Air box drains?
Sounds like where all the water drips out of ya air con?
If it is....
We got them airboxes in the dongas down ere ay..
chocs
ps..
none of them dog tucka tins under them Cummins fellas ..
Air box drains?
If it is....
chocs
ps..
Time to create page: 0.439 seconds
